Topic: Current state of Total Mix FX and surround formats
hi
Currently using a Madi FX via an SPL 7.1 analog monitor controller to do 7.1 surround mixes
I'm going to go Dolby Atmos and the SPL controller obviously won't support the extra .4 speakers so I was thinking of buying the RME ARC controller to use instead.
I don't normally touch Totalmix as I do everything direct in Nuendo (I know I'm missing out !)
I know I can group faders to make this work but there was talk of this being natively supported in the control room
https://forum.rme-audio.de/viewtopic.php?id=21451
I also see 1.7 b5 is out but the release notes seem a little thin ? - Is this now supported ?
thanks
Re: Current state of Total Mix FX and surround formats
Sorry, not supported right now.
Thanks Matthias
is it still on the 1.7 roadmap ?
Roadmap yes, 1.7 not.
ok - patience is a virtue smile
(even if it has been several years)
can you bear in mind, if you do implement it, that surround isn't just 5.1 anymore.  Atmos and other multichannel audio is pretty big so it would be good to cover all these more common ones.
I'll pick up the ARC anyway and see if it fits my workflow.
thanks again
Just adding a +1 to this feature request (surround support in the Control Room, Dolby Atmos support, even if possible fine tuning adjustments like delay compensation, ...) if it can help move up this feature request in the priority list wink.
I’m considering selling my RME audio interfaces because of this.
+1 for this functionality!  I'm using output EQ to do top / sub crossover point and using OSC to fade a fader group of main, rear and sub outputs in order to make a DIY 4.1 controller... It's far from ideal, but it works ok.  I'd love some dedicated functionality for this, including proper crossover assignment / bass management and some delay on the outputs (as mentioned in the previous post) for alignment purposes.
Pretty please?!
Yes, that would be super useful.
If you desperately need a delay on a stereo out, there is this workaround using the Echo:
https://forum.rme-audio.de/viewtopic.php?id=26978
Unfortunately the delay values are too course for doing time alignment. You need increments of 0.1ms
ah yes, I was not aware that this is not possible with the echo, too bad.
I´m in the process of building a recording studio with dolby atmos mixing capabilities, i wanted to use all RME AVB and Madi devices but the lack of Dolby monitor control, dedicated delay lines and EQ, just throw me off.
For now my solution is, HDSPe MADI FX for routing and headphone mixes, MADI stream into Directout Prodigy MC (64 analog I/O for connecting all the outboard gear and Dolby speaker setup, Ravenna stream into a Merging Anubis for monitor control and speaker management.
So please RME...Run.
I have absolutely no information on RME's roadmap, however, I am certain, ATMOS would be on the radar.
Personally, I would love to do the upgrade to Atmos sometime soon in the future and of course I would love to continue using RME equipment (as I have for the last 25?? years since the Multiface was released).
Yes, I messed with other gear, but that always leads to wishing they could take the RME lead and make reliable drivers and continue to support their infrastructure.
So yup, keen to see what may eventuate!! :-)
Matt McKenzie-Smith
On the radar ? - yes, but they still haven't really embraced 5.1 (despite 'promises')... which is decades old big_smile
Totalmix is already close of making it work for atmos as far as I can tel. Group multiple output faders, there is EQ. Just the adding a time delay on output channels would be great. When that's there the RME stuff would be an amazing alternative to some super expensive solutions.
Some kind of bass management solution would be great too.
There is always the option of routing to some dedicated software on the way in / out of the computer as well, but doing it in Total mix / RME DSP with lower latency would be preferable.
