1 (edited by foucauld.legrand 2021-09-14 15:59:26)
Topic: HDSPe MADI doesn't work on computer which I made firmware update with
Hi there,
Hope that topic wasn't too much spoken about here.
I updated (or tried to do so) the firmware of my HDSPe MADI v1.1 card. The process never started and I wasn't able to close the "update window". I finally closed it through the ctrl+alt+suppr way. The card isn't working anymore on this computer. It appears with the yellow triangle on the window's peripheral list . I uninstalled and re-install the drivers, tried again the firmware update process but the application is not starting at all.
I then tried the HDSPe Madi card in an other computer, it worked like a charm.
How can I make it work on the initial computer ?
Thanks !
PS : "computer" is a PC running Windows 7, I used the driver packaged contained in : driver_hdsp_win_438.zip & the firmware updating tool contained in : fut_wdm_dspe.zip both issued on June 2021
Re: HDSPe MADI doesn't work on computer which I made firmware update with
Update the firmware on the computer where the card works. If there is an update at all - you did not tell us what firmware it is/was on.
In Device Manager, did you right click on the marked HDSPe to get more info and options to re-enable the card?
3 (edited by foucauld.legrand 2021-09-15 10:23:47)
Thanks for replying.
It was a driver issue, not a firmware one.
Cards got firmware v33.
Don't know why but as soon as I installed back the 4.28 driver package, everything worked fine again.
I re-tried the 4.38 and it still was a fail.
So to be clear, both this HDSPe MADI card and an other AES one work perfectly with 4.38 on the windows 10 computer; but fail to operate with 4.38 on the windows 7 computer.
4.28 make the cards work perfectly on this last one, which is ok to me.
Have a good day.
Well, issues with W7 due tio missing updates is nothing new:
https://forum.rme-audio.de/viewtopic.php?id=30486
https://forum.rme-audio.de/viewtopic.ph … 79#p160879
https://forum.rme-audio.de/viewtopic.ph … 45#p171745
