Topic: RME UCX II monitor options
Newbie here.
Is it possible to use the SPDIF-outputs as monitor outputs? My Neumann KH 120 II have SPDIF inputs.
Thanks.
2 (edited by waedi 2024-10-15 08:06:47)
Re: RME UCX II monitor options
Hi Nevets
yes, in Totalmix route signal to this output.
Do you know how to do that ?
you need the breakout cable, you have it ?
Hello
I have never used the SPDIF outputs but we can route all the I/O's from the CHAN/MIX front encoder on the UCX II, so you may choose to do it via TotalMix or via stand-alone.
UCX II 106/34/104 v1.253 TM1.97 - PC Win11 23H2 / Fedora WS 40 - Reaper 7.25
My chain is UCX II -> S/P-DIF -> ADI-2 Pro -> S/P-DIF -> KH 750 DSP -> analog -> KH 120 A. Everything works like a charm.
So it's not only possible, it's recommended.
Fireface UCX II + ARC USB > ADI-2 Pro FS R BE > Neumann KH 750 DSP + MA 1 > KH 120 A
