Topic: RME UCX II monitor options
Newbie here.
Is it possible to use the SPDIF-outputs as monitor outputs? My Neumann KH 120 II have SPDIF inputs.
Thanks.
RME User Forum → FireWire & USB series → RME UCX II monitor options
Newbie here.
Thanks.
Hi Nevets
yes, in Totalmix route signal to this output.
Do you know how to do that ?
you need the breakout cable, you have it ?
Hello
I have never used the SPDIF outputs but we can route all the I/O's from the CHAN/MIX front encoder on the UCX II, so you may choose to do it via TotalMix or via stand-alone.
My chain is UCX II -> S/P-DIF -> ADI-2 Pro -> S/P-DIF -> KH 750 DSP -> analog -> KH 120 A. Everything works like a charm.
So it's not only possible, it's recommended.
Why not straight from the UCX II to the KH 750 DSP?
