1 (edited by hpw 2019-06-25 16:02:20)
Topic: Subscription/notify for Firmware/Driver Updates ADI-2 Pro & ADI-2 DAC
This thread is a "Firmware/Driver Updates ADI-2 Pro & ADI-2 DAC" subscription notify ONLY thread!!
This means, all are welcome to "Subscribe" to this thread and get a notify as soon someone sees a beta or release Firmware or Driver published from RME and add's a related message.
How to subscribe: Login and than you will see a "Subscribe" Menu entry on to top left blue bar and simple click to this to get the update news letter. big_smile
Hp
Re: Subscription/notify for Firmware/Driver Updates ADI-2 Pro & ADI-2 DAC
Firmware Updates ADI-2 Pro 193 / 94 and DAC 26 / 29 out now: https://www.forum.rme-audio.de/viewtopic.php?id=28936
New windows driver:
Windows 7 to 10 PnP driver for MADIface XT/USB/Pro, Fireface UFX+ / UFX II, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, Digiface USB. Version 0.9685
https://www.rme-audio.de/download/drive … _09685.zip
[ADI-2 DAC] New firmware
Firmware Update ADI-2 DAC 26 / 30 - Remote it!
[ADI-2 Pro & DAC] New firmware
Firmware Update ADI-2 DAC 27/32, Pro 213/96 - Fix it!
Firmware Update ADI-2 DAC 27/33, Pro 213/97
https://forum.rme-audio.de/viewtopic.php?id=29439
7 (edited by hpw 2020-03-15 15:04:05)
Firmware update on DSP part..
ADI-2 Pro series: FPGA 213, DSP 98
ADI-2 DAC: FPGA 27, DSP 34
8
No update:
https://forum.rme-audio.de/viewtopic.ph … 72#p148272
Flash Update Tool for MADIface XT/USB/Pro, OctaMic XTC, ADI-2 Pro Series & DAC, Digiface USB, UFX II.
2020-09-17
Update to firmware revision MADIface XT: 191/56/42, USB: 25, Pro: 73. OctaMic XTC: 47/26. ADI-2 Pro: 238/98, ADI-2 DAC: 34/34, Digiface USB: 14, UFX II 20/11/7.
Supported products
ADI-2 DAC FS, ADI-2 Pro AE, ADI-2 Pro FS, ADI-2 Pro FS R Black Edition, Digiface USB, Fireface UFX II, MADIface Pro, MADIface USB, MADIface XT, OctaMic XTC
Warm regards,
Bernhard Rother
enjoy-audio.de
2020-09-17
Supported products
BTW .. appears to me the same as post #7, could you kindly review ? I will remove my post here after a while to clean-up.
BR
Ramses
X10SRi-F, E5-1650v4, Win10Pro20H2, Cub11 Pro, UFX+, XTC, 12Mic, ADI-2 Pro FS R BE, ARC USB
11 (edited by bejoro 2020-09-26 13:44:42)
The version nunbers should be clear.
Post #7 is a different and much older  firmware. The new firmware is from 2020-09-17.
Warm regards,
Bernhard Rother
enjoy-audio.de
12 (edited by ramses 2020-09-26 14:04:38)
Never too late to learn a new trick.
Thanks, up to now I thought that only the DSP version (which is shown on power-on in the display) would be relevant to identify, whether a firmware upgrade is needed.
I think then it would be better to display both numbers on power-on, the USB and DSP version to make it clearer, whether an upgrade for a particular device is required.
Especially as this updater is for different devices and sometimes there is only an update included for some of them.
@RME: would that be possible ?
Thinking back to the good old Webserver, where this update information was based on the device not on the driver (where you have to look closely, whether it contains an interesting update). That was much easier and clearer.
BR
Ramses
Yes that would be very helpful. RME please show FPGA and DSP version of the firmware at startup.
Warm regards,
Bernhard Rother
enjoy-audio.de
2020-09-17
Supported products
I can't find version history / change log, what's new?
Because there is none yet.
Warm regards,
Bernhard Rother
enjoy-audio.de
Thanks,and where can I found what changes are?
17 (edited by bejoro 2020-09-26 15:43:17)
Download the flash updater tool for your OS and look into the readme.txt.
Not very detailed but a hint.
09/17/2020 ADI-2 Pro updated to 238/98, ADI-2 DAC updated to 34/34. Current peak on power-on reduced.
Maybe MC will provide a more detailed change log if he finds the time (and if necessary).
Warm regards,
Bernhard Rother
enjoy-audio.de
Are all firmware and driver updates supposed to be announced here? The reason I ask is I just noticed driver update 0.9728 when I checked at the support page directly (dated 2020-10-31) that does not seem to be mentioned here. It seems official (not mentioned as beta) so I'm wandering why it would not be announced via this sticky thread?
You just did. Thank you.
Warm regards,
Bernhard Rother
enjoy-audio.de
Version 0.9728
Unterstütze Produkte
ADI-2 DAC FS, ADI-2 Pro AE, ADI-2 Pro FS, ADI-2 Pro FS R Black Edition, Digiface Dante, Digiface USB, Fireface UFX II, Fireface UFX+, MADIface Pro, MADIface USB, MADIface XT, OctaMic XTC
Wo findet man eigentlich die Firmware für RME ADI-2 PRO (den Erstgeborenen) - oder kann man dazu auch obige nehmen?
Adi-2 Pro, Adi-2 Dac Fs
This is a thread for notifications only. Please open a new thread if you have questions.
Warm regards,
Bernhard Rother
enjoy-audio.de
Ok - I assumed this was supposed to be announced by RME folks but if its open to anyone to mention it when they notice new versions that works as well.
