Topic: Beta: MIDI Remote for 12Mic and AVB Tool
For users who operate the 12Mic or AVB Tool from a distance (stage box etc.) with MADI connections, the lack of a MIDI Remote control software meant that they had to install a separate LAN cable or WiFi connection just for remote control - and, in most cases, just to set or adjust the gains once during sound check. For this reason, we have developed a separate app, "RME MIDI Remote AVB", which offers basic remote control (analog I/O controls such as gain/volume and phantom power, preset switching etc.).
Usage:
1) Install on a computer that has a MIDI over MADI interface.
2) Configure 12Mic/AVB Tool on device:
- press encoder for menu
- press encoder again for STATE
- rotate to REMOTE and confirm with encoder
- press MIDI softkey
- select input and output corresponding to the MADI format, ie. optical or coaxial
- set MIDI ID
3) In the MIDI Remote AVB application, press "Conf", select MIDI over MADI input and output, confirm each with "Apply". Return to main screen and add device. On the left side, choose the corresponding MIDI ID.
Notes:
- It is not possible to synchronize the entire device state over MIDI, so features such as routing will have to be configured on the device or over the webUI/API/AVDECC. However, since preset control is implemented, users can create complex configurations and toggle between using presets. Keep in mind that loading presets might change settings that are not visible over MIDI Remote AVB, such as clock source, routings, etc.
- "Snapshots", on the other hand, are locally stored on the computer and only include the analog channel controls. This is useful, for example, to store and recall gains for different sessions.
- Hold the [Shift] key while dragging an encoder for fine adjustments.
!!! Requires Firmware 1.4.0 beta or later !!!
Download newest firmware here: https://forum.rme-audio.de/viewtopic.php?id=33265
Download MIDI Remote AVB:
Windows installer
macOS application
We are looking forward to your feedback.
Re: Beta: MIDI Remote for 12Mic and AVB Tool
Great! Can it coexist with the old Midi Remote?
Georg
3 (edited by Max 2021-06-10 11:14:10)
That works in our tests so far. The 12Mic and AVB Tool have their own SysEx header, so an XTC and a 12Mic can also have the same device ID (both devices could have device ID 1, for example).
But please test and let us know if you encounter any issues.
4 (edited by georgob 2021-06-13 09:46:09)
In my setup xtc, 12mic, 12mic,
Midi remote for octamic on, avb remote on.
Avb looses its connection after a time and cannot be reconnected.  I have to close and open it again.
Old midi remote is online the whole time.
And Sequoia is recording, sending midi remote play, rec, stop commands.(for use with a punchlight)
Georg
I could reproduce it (Windows only) - we'll fix that.
-Max
Great, thanks.
Georg
It would be great to be able to name the channels.
In my setup the 12mics are for ch 9 to 20 and 21 to 32. I'd like to remember them in the remote, or give instruments name to them.
Georg
This is great, a total godsend - nice little bit of software too, maybe even preferable to the aux-device solution! It's very clear visually, super simple to see things in the heat of battle! Is the plan to fully "release" the Midi Remote for 12mic/AVB tool, or is this just a stop-gap and all future updates will be for aux-device only?
One quick question - I can only get this to work using midi port 4 (fireface ufx+ and 12mic connected via coax) - any reason port 3 wouldn't work?
Thanks for the feedback! Yes, this will be released in future.
Regarding port selection on UFX+ - port 3 corresponds to the optical MADI signal. If changing the entire setup to optical connections, choosing MADI optical in and out in 12Mic/AVB Tool MIDI setup, the communication should work as well.
Morning Max, Matthias.
Just as an idea. This information should maybe be added to the UFX+ manual.
Although it appears logic after knowing it, it might be challenging when a device is new to directly/fully understand, that
- UFX+ MIDI port 1 and 2 are related to the two MIDI channels/busses on the device and
- UFX+ MIDI port 3 and 4 are related to MIDI over MADI through optical / coaxial MADI
BR
Ramses
X10SRi-F, E5-1650v4, Win10Pro21H1, Cub11Pro, UFX+, XTC, 12Mic, ADI-2 Pro FS R BE, RayDAT
11
Hi Ramses,
I found it in the manual / 21.4 MIDI second paragraph.
Great, then it has been added (had the old status still in mind).
BR
Ramses
13 (edited by klafkid 2021-07-18 17:44:25)
Thank you for this software! I am unable to connect via my MADIface Pro.
The manual says the MADIface Pro should provide a MADI Port called "MADI  Pro  Midi", but the only MADI Port shown in AVB Tools is "MF Pro MIDI", which in the manual is described to be connected to the 6-pin MIDI port.
Is MIDI Rremote AVB not set up for the MADIface Pro yet?
14
Hi klafkid,
we will release a new beta that can recognize the second MF Pro MIDI port by next week & update this post accordingly.
Best regards,
Max
15 (edited by georgob 2021-07-21 12:17:10)
A small bug - the first channel in the midi remote AVB turns completely yellow when turning the gain. No other knob behaves like this.
https://ibb.co/s1kNqsB
Georg
Georg
Must be the "golden voice feature"
The mac version is without that feature.
Have you version 0.9.9 ?
M1-BigSur, Madiface Pro, Digiface USB, Babyface silver
