Re: New macOS RME USB 4.06 driver – public beta test
naturligasteg wrote:I read that as there are no need to remove anything manually if the installation goes through.
Exactly.
naturligasteg wrote:Where is that part with files to remove?
In the manual, chapter driver deinstallation.
naturligasteg wrote:ILooking at settings in Fireface I have Firmware: v19 Driver: v4.06 beta now. Where can I see if there is something old left on this Mac?
You don't and don't need to. If there is something left you would get the same error message as the other user.
naturligasteg wrote:What is the full process to remove all and install drivers from scratch if that may solve the pop and stop play back issue?
It doesn't.
naturligasteg wrote:II have tried different usb port and is seems about the same... goes many hours without any issues and the suddenly there is a pop or stop or two...
In the end it is Apple's responsibility to make DriverKit work without such effects. THEY put DriverKit on all of us, and THEY decided that a not-kernel based solution is good enough for anyone. Although technically that is more than questionable.
That said pops and clicks can also happen with kernel-based drivers.
Hi MC!
I have tried all the methods in this post, but still get pops and clicks while payback on my Babyface Pro FS with firmware 201 and driver v4.06! Is there a solution yet for this or do we just have to wait for another version to come? Years of flawless drivers with RME on Intel so I guess its an Apple problem. Strangely though when I use my FF800 on the same M1 MacBook Pro it runs flawlessly. When can we expect a solution for this as its impossible to run a session because of all the glitching.
Thank you!
