Re: ADI-2 Remote Pre-Release: Step 1, macOS (Update: released)
I had the same problem. This happens when IpadOS settings> display and brightness> screen zoom> larger text. If we activate the default size then the application works correctly. The problem should be solved because there are many of us with visual difficulties who have this option activated
This statement confuses me. The option is called 'Display - Display Zoom - More Space' on my iPad Pro, and performs the exact opposite - everything gets smaller, so not good for visually impaired. The option to change the Text Size is a different setting and does not cause any operation error with the GUI.
