Gautier wrote:So new questions : do you have any idea how to tackle the "SETTINGS" situation ?
Does it come from my setup ? And how to tackle the 9-12 extra 4 preamps within TM ?
Take another look at the screenshots, that's why I made them for you.
My channel distribution on the MADI BUS, related to the screenshots above...
ch 01..08 = Octamic XTC
ch 09..16 = 12Mic Port 1-8
ch 17..20 = 12Mic Port 9-12
Assumed now channels 1..12 for your 12Mic., see below.
It depends on how you have configured the routing on the 12Mic regarding its mic channels from/to MADI Bus (ch 1..64).
General info: since the device no longer corresponds to the 8-port scheme of the Octamic XTC, RME had to come up with something new. The idea here is to enter the 12Mic in groups of 4 ports to support Mic preamps with 4, 8 and 12 Ports.
12Mic Port 1-4: MADI channel 1..4
12Mic Port 5-8: MADI channel 5..8
12Mic Port 9-12: MADI channel 9..12
This is what you have to configure now under TM FX -> Options -> Settings (F3), Tab “Aux. Device” tab
Select the Channels (Bank, 8 ports) and enter the ports of your 12Mic under Device 1 and Device 2 in groups of 4.
Device ID, this is the MADI ID of your device, most likely 1 if you have 1 device.
Set MIDI In and Out to UFX III Midi Port 3 (this is MADI optical).
Channels "MADI 1-8":
Device Type: 12Mic 1-4, Device ID: 1, MIDI In + Out: UFX III Midi Port 3
Device Type: 12Mic 5-8, Device ID: 1, MIDI In + Out: UFX III Midi Port 3
Channels "MADI 9-16":
Device Type: 12Mic 9-12, Device ID: 1, MIDI In + Out: UFX III Midi Port 3
Device Type: None
